QUOTE(SirAndy @ Aug 1 2007, 11:50 AM)
QUOTE(Joe Ricard @ Aug 1 2007, 11:21 AM)
If you mount a Sparco to the floor the front cross brace is in the way unless you take off the sliders and then the seat better be EXACTLY where you want it and are the only driver.
since when does that slow us down?
i know the cross-brace is in the way for certain seats. easy fix, get a plasma cutter and cut out the brace about 1/4" above the floorpan.
clean the inside with ospho (or similar product), cut off top of crossbrace and weld it back on.
add a similar brace (about 1/4" high) to the rear and voila! you got yourself a nice front and rear support for your seat.
Andy
The crossbrace will probably be in the way with these seats. In addition, I MAY let my wife drive it when it is done so sliders will be nice. Also, the cross brace in my car is pretty rusted and in need of replacement along with the floorpan so some
and
will be required either way. Funny thing is, the brace is actually in worse shape than the floorpan. I think the tar kept my pan pretty well protected from the leaking rear window. Previous owner
