7TPorsh
Aug 1 2007, 06:10 PM
Well, like it says. got primer over spray on the decent roller tires I have; they will be promoted to driver tires once the car is off its stands.
What's the best cleaner? Paint thinner? Acetone?
r_towle
Aug 1 2007, 06:40 PM
type of paint needs to be part of the question.
Rattle can primer...goof off.
Two part epoxy primer...sandpaper
Two part acrylic enamel primer....sandpaper
Rich
scotty b
Aug 1 2007, 06:50 PM
Go to the local paint supplier and drop $25.00 for a set of wheel covers
As for removing the pain tyou can try laquer thinner and a scotch brite pad.
scotty b
Remember kids overspray gets EVERYWHERE !!!!
skline
Aug 1 2007, 07:31 PM
Scotty is right, I would have said steel wool and thinner but a scotchbrite pad will work almost as well, the steel wool will conform more to the tire than a flat pad.
black73
Aug 1 2007, 08:16 PM
Spray the overspray with flat black or black primer.
Pat Garvey
Aug 1 2007, 09:07 PM
Please! Stay away from acetone! Never ever use it!
Trust me, I worked with this stuff for years. It's explosive, carcinogenic, and just plain bad for the environment when set loose (no, I'm not a tree hugger - this is really BAD stuff).
How about trying this....Mr. Clean double strength Magic Eraser. Not nearly as abrasive to the tire as steel wool/SOS, yet it WILL take the crap off. Follow directions.
Pat
Primer should deteriorate pretty rapidly- especialy when undergoing constant deformation. Let it sit until time to be driven, then remount with it reversed on the wheel. you may have to do all four to match properly.
