I'm trying to reassemble my previously working L-Jet system to do initial break in on my rebuild .
As i am hooking up all of the vacuum lines per the PP layout i realize that i do not and did not have parts of the system previously on the engine.
No egr or decel valve and now i've switched to the mallory so no vacuum there either.
so do i plug the 4 mm outlet on the throttle body?
run the 5 mm directly from the fuel regulator to the plenum?
run the 19mm line from the Y fitting directly to the plenum?
or did i miss place one of these items and she'll never run again....
on a side note I'm switching to SDS as soon as break in is completed and she's close to being in tune,
and forget about the charcoal canister as the PO mechanic must have removed that as well
