these are keith black hyperetectic 96mm pistons that have appx. 1000 miles on them. today we got them cleaned up, checked them and the pins for wear. good shape. my 2 questions are:
1 the pistons dont appear to have a mark indicating "down" or otherwise. they do have universal oil drain holes under the oil rings on each skirt side. in other words the side that would be on the lower/bottom. it appears they can be installed either way?
2 what type retaining clip is recommended as better to hold the full floating piston pin (i.e. spiral,snap ring ect...)? has anyone got good or bad info. on the nylon plugs i've seen used in the type I? sounds like a gimmic to me.
mike
