orange914
Aug 2 2007, 11:05 PM
i understand the inportance of dialing in the pushrod length and buying/building acordingly. i've never seen a whole adjustable set used perminately. this sounds crazy
mike
Dave_Darling
Aug 3 2007, 12:03 AM
Are those pushrods, or pushrod tubes? They look a little short (or a little wide) to be pushrods... The collapsable tubes can be a real godsend on the Type I (and the 911!) engines, where you have to remove the cylinder head to change the seals on the end of the tube.
--DD
Twystd1
Aug 3 2007, 03:48 AM
Yes I have used them.
On Harleys.
CCC
Jake Raby
Aug 3 2007, 06:30 AM
Totally incompatible with the TIV engine. The TIV has a design that allows the tubes to pass through the head being sealed with an O ring design.
DNHunt
Aug 3 2007, 10:18 AM
Those look just like the Type 1 pushrod tubes we got for my son's bug.
Dave
Cap'n Krusty
Aug 3 2007, 11:57 AM
Not only are they T1 (or maybe 356) adjustable pushrod tubes, they're of the type we refer to as "leakers". As they're of fixed length after installation, they don't allow for thermal expansion, which is a real problem with T1 and 356 engines. The good ones, if there is such a thing, are spring loaded. Been there, seen that ....... The Cap'n
