QUOTE(jaybird840 @ Aug 4 2007, 04:40 PM)
OK, so does anyone have a writeup on rocker removal? I really want to make sure the heads are snug on my new teener before I start tuning it up....
Remove the spring clip which holds the push rod tubes in place - then unscrew the 2 nuts w/washers on each rocker. The rockers just slide off the studs. Take the entire assembly off together (pretty much have to anyway).
Hate to say it, but installation is the reverse of removal. On the install make sure the spring clip is pushing against the bottom of the push rod tubes - otherwise it is a useless piece of spring steel.
It's a bit of a pain in the ass w/the engine in the car but not all that bad. Just make sure the car has cooled down as you'll be bumping your hand (maybe even your nose) on the header/heat exchangers.
-pt
