levonfarra
Aug 4 2007, 03:19 PM
on cold days its ok, but in the summer it is killing me.
thanks for your help.
Lev
Bartlett 914
Aug 4 2007, 09:30 PM
Mine does a little. Your flappers may not be fully closed. It also may be that the gasket inside the flapper (flappers) could be damaged / gone.
ConeDodger
Aug 4 2007, 09:43 PM
QUOTE(levonfarra @ Aug 4 2007, 02:19 PM)
Lev
I find that my 911 blows hot air all the time when I have the AC on... So it must be normal.
Seriously, check to see if your cables have slipped and you still have it set on heat.
QUOTE(Bartlett 914 @ Aug 4 2007, 10:30 PM)
Thats my situation. Since I put on those SS heat exchanger It will melt your tennis shoes....
Bartlett 914
Aug 5 2007, 08:47 AM
QUOTE(SGB @ Aug 4 2007, 10:08 PM)
Who says the 914 doesn't have good heat.
rhodyguy
Aug 5 2007, 10:01 AM
prob the gaskets are shot or just plain gone in the valves. make sure the control wire (red knobed handle on center tunnel is pushed fully down) is not holding the valves partially open. to temper the 'constant heat', use the dash controls to direct the hot air to the defrost vents and mix with fresh unheated air. it will help alot and keep your feet cooler.
k
pba110
Aug 5 2007, 11:45 AM
you could also just unhook the tubing in the front trunk and plug it with some post office shipping material (non flammable i believe) until winter comes back around...right?
rhodyguy
Aug 5 2007, 11:55 AM
or just fix the problem.
k
I think the best way to fix your hot air problem is to take your exhaust off and get a set of headers. You don't drive it in the bad stuff now do you?
Brando
Aug 5 2007, 06:04 PM
What material is the padding in the flapper boxes made from? Asbestos?
What would be a viable high-temp resistant material to repair them with? I have the same issue...
r_towle
Aug 5 2007, 06:55 PM
remove the flexible hose that goes from the heater flapper boxes to the tube in the body.
It can be done without jacking the car up, with a flat screw driver.
Save the clamps and hose in the trunk, just in case you need it one cold morning.
All better.
Rich
Phoenix914
Aug 6 2007, 09:13 AM
QUOTE(r_towle @ Aug 5 2007, 08:55 PM)
All better.
Rich
That's what I did. Those hoses are supposed to have clamps on them?
