QUOTE(dflesburg @ Aug 6 2007, 11:39 AM)
how do i check that? cant see it from underneath the car. not even sure I can see it with the pedal board out of the way...
perhaps moving the brake pedal when stone cold to feel for resistance...
The way I check that is to remove the pedal board and unscrew the jam nut and (with my fingers) run the actuator rod down until you feel it contact the piston and then back it off part of a turn and then tighten the jam nut.
I only suggest checking this as you had your entire car apart recently.
Once adjusted and tightened down, it will never require any future adjustments unless the master cylinder is replaced.
Air is a possibility, but I never heard of air giving a nice solid pedal. Since all air that I know of compresses, I would still expect a squishy pedal.
As fluid heats up, it typically will expand.
You could also have a brake pad dragging.
By all means, rebleed your brakes.
