QUOTE(Bogaat @ Aug 9 2007, 12:15 PM)
QUOTE(914-8 @ Aug 9 2007, 03:06 PM)
Looks good!
On the colorsand, you won't be able to buff it out with a random orbital. It doesn't generate enough speed to get out sanding marks, even from 2000 grit paper.
I have the Porter Cable 7424 polisher...dual action...should be good? I may not have been thinking when I said random orbital...
That Porter Cable is excellent for applying waxes and light polishing of minor swirls, I have the same one.
But it won't work for polishing after a colorsand. You need a more aggressive cutting compound to get out colorsanding scratches (even from a 2000 grit colorsand).
Whatever brand of compound/polish you use (Meguires, 3M, etc.) for your initial polish after the colorsand, it is going to be designed to be used with a high speed buffer, not something like a PC 7424, which generates little to no speed or heat. The more aggressive compounds designed to be used as a first cut after a colorsand are designed to be used with a certain speed and heat generation, and are pretty much useless when used with a random orbital like a PC 7424.
Of course, since you already have the PC 7424, there is no harm in trying it out. I did, but quickly found it didn't work.
