jaybird840
Aug 6 2007, 04:51 PM
Missing a nut off of one of my exhaust studs. Thought I found it at my FLAPS but wouldn't fit when I got home.... What's the correct size?
davep
Aug 6 2007, 04:55 PM
Should be an M8. Better to get a proper nut for the application eventually. A standard nut will probably not last long.
McMark
Aug 6 2007, 07:23 PM
M8, but most M8 nuts use a 13mm wrench. You need the M8 that uses a 12mm wrench. The larger ones will sometimes hit the tubing.
type47
Aug 6 2007, 08:10 PM
isn't it a special copper nut?
URY914
Aug 6 2007, 08:30 PM
QUOTE(type47 @ Aug 6 2007, 06:10 PM)
Yep. I got 'em.
Copper nuts=brass balls
A vee- dub place should have 'em too.
