After chasing numerous no start problems I have decided to attempt to remove a 70s/80s kill switch alarm system from my 72 914.... already removed about 12 feet of wire (thats around 4 meters give or take) from the fried switch under the seat. and criss crossing the engine bay... now it cranks! but no fuel and the horn goes off when the key is in start position.
So the thing I am on to now is the fuel pump. right now one wire goes directly to the negative bat terminal and the other goes to one side of the coil. Should this work? Should the fuel pump see 12v at all times when the key is in the run position??? I am also in need of a diagram for the fuel lines. mine are all unhooked and hanging down under the car where they come out of the pump. any help?
