degreeoff
Aug 7 2007, 10:04 AM
Who knows what in the back of the 911 gauges does what? IE: the gauges have 3 symbols + (I would imagine thats battery? A ground symbol (looks like a busy telephone pole) and the letter G which does what???
McMark
Aug 7 2007, 10:37 AM
Which 911 gauge? Picture front/back?
degreeoff
Aug 7 2007, 10:41 AM
well at this point (pelican rocks too) I need to know if the OEL gauge is a duplicate of the pressure gauge or for a oil level...? I do not have an oil level sender anywhere that I know of (6 conversion)
Thanks!!
markb
+ is hot, The "telephone pole" is ground, the G is from the sender.
McMark
Aug 7 2007, 10:44 AM
An oil level gauge would have the warning down low, and a temp or pressure gauge would have the warning up high. Most likely you're looking at + get 12v switched with the rest of the gauges. The 'tree' is the standard ground symbol, so hook a brown wire there. G would be the signal wire from the sender. In this case, likely a pressure gauge, although without seeing it....
