QUOTE(xperu @ Aug 8 2007, 01:13 PM)
I just removed mine, I really don't know if it's the best way, but i removed the screw at the to pf the sail trim, turned the trim counterclockwise about half way turn, then push from the bottom flat wide end. It has a glob of some kind of seal material on the flat shaped fastener holding the sail trim. You just have to be careful when pushing on the trim(be patient) not to bind the trim piece, I had to wiggle it back and fourth several times. Put tape down around the area to prevent scratching the paint. I'm sure there is another way, but worked for me on both my cars.
See I told you there was another way!
