Heres what I got; this is a 71. At the low beam connection on the light socket, I got 8.5 volts at the ground on the plug. I jumped from the battery to the low beam plug at the socket and got 8.5 volts. I went to the fuse box and jumped from the 1st fuse to the body and got 8.5 volts. As you know, the 1st and 2nd fuses are for the head lights which have the same voltage since they are jumped there on the fuse pannel. The right light is bright and the left light is very dim. Is all the power feeding the right light? I should have unplugged the right one and see if the left got brighter but just though of it. Does this ring a bell with anyone? The lights were fine a month ago and now they are funny. Bad ground? Got any idea?
