Previous owner moved the fuel filter after the fuel pump, up top in the engine bay. I ordered a stock replacement and want to put in the correct location, which I understand is before the pump. I have the firm fuel line coming from the tunnel, and then the larger rubber line that leads to the pump is just clamped over it. Does the firm rubber/plastic line coming from the tunnel hook directly up to the small inlet on the fuel filter? I'm wondering if it is flexible enough to fit over the barbed fitting?
Another stupid question... How do you prevent the fuel tank from draining through the fuel line when you disconnect it? Or is a gasoline shower just part of the job?
