pjhaun
Dec 21 2003, 03:04 PM
Here is a picture of the chromed Boxxter rims on my 914 (front)
pjhaun
Dec 21 2003, 03:08 PM
Here is another picture on the chromed Boxster rims I put on my 914 (rear)
Andyrew
If only they where 17 in.. Still looks nice!
Works well with the body.
Andrew
Jeroen
Dec 23 2003, 07:18 PM
Very nice!
Can you post any specs...?
Wheel sizes, ET/offsets, spacers used?
cheers,
Jeroen
scottb
Dec 23 2003, 08:01 PM
boxsterfan
Dec 23 2003, 10:31 PM
Those look great! Still gives me the feel of the "era". 17" rims would be too huge. I always thing the 914's with 17" rims look a little awkward even with mondo flares.
Malmz
Dec 24 2003, 12:07 AM
Phillip,
Definitely interested in hearing what spacers you used (since nobody could give me an answer to my hypothetical question a month ago!)
Let us know.
sm
pjhaun
Dec 24 2003, 12:41 AM
They are stock 1997-98 Porsche Boxster rims chromed. The front is 6x16 with an offset of 5 1/8 inches. I used a 1 1/2 inch spacer. The tire I used is 205/55-16. The rear is 7x16 with an offset of 5 5/16 inches. I used a 1 inch spacer. The tire I used is 245/50-16.
smrz914
Dec 24 2003, 01:47 AM
17 inch 993 wheels so you can decide if they are to big.
sj914
Dec 24 2003, 02:38 AM
Paul, the picture's too small.
I thought the 17's were too big to.
But seeing your car in person with those 17" changed my mind.
Malmz
Dec 24 2003, 10:37 AM
QUOTE(pjhaun @ Dec 23 2003, 10:41 PM)
Any idea of how much inside clearance you have in the front at full lock? Wonder if I could run a rear wheel on front with a 1" spacer all the way around.
sm
smrz914
Dec 24 2003, 03:42 PM
i ended up posting the thumbnail, let's try again.
pnewman
Jan 19 2006, 07:54 PM
I see alot of 911 rims on ebay for sale. Occasionally cheap. Seems as though they came w/ 17" front x 7" and rear x 9" some auctionaires state a 55mm offset ??? hmmmmmmmmmmmm
has anyone tried getting 4 each of the 7" ones and putting them on a 914? would you have to have fender flares? would you have to use spacers?
just looking down the road at converting to 5 lug from 4 and would only do it if I could put on pretty wheels. aaaaaaaaaaaaaaaaaaaaaah
pete
mskala
Jan 20 2006, 11:06 AM
Yes, several people in several threads did 7"x16" boxster without mods. The 40mm offset is
nearly perfect. I now have a set which will hold my 205/45/16 Kumho V700's, but not ready
yet.
Mueller
Jan 20 2006, 12:48 PM
QUOTE (pnewman @ Jan 19 2006, 06:54 PM) |
pete |
for a just about perfect setup, a 7" rim with a 205 would need a 35mm offset, so with a 55mm offset 7" rim, you'd want to run a 20mm spacer on the rear.....
for the fronts, you can actually get away with a larger spacer such as 25mm or even wider since the track on the front is 1" per side narrower on the front the rear........
Root_Werks
Jan 20 2006, 02:29 PM
914 looks great!
