r_towle
Dec 21 2003, 03:31 PM
ok,
I have this race car...
I have a tail shifter and a side shifter...
My question is this...without taking off the rear/front cover of the tranny and removing all the gears, can I figure out what type of Diff is in there??
When I spin one axle forward the other goes forward as well...Chris mentioned that I may have a locker or Locked diff and that running autocross would be a chore with this...
It seems that I could remove the axle hub from the right side and pull off the large plate behind it....but then what would I be looking at and how would I know if its a locker or limited slip??
Help Please
Rich
Brad Roberts
Dec 21 2003, 03:42 PM
Got a friend close by ??
You hold one wheel.. and have a friend try and turn the other. It only takes about 80lbs to break a LSD loose. If you cannot break it loose.. (at all.. lots of trying).. then you have a locker.
You hold it one way.. while your buddy tries to turn it another.
Another idea.. leave one wheel on the ground and you try and turn the one in the air (no friend required)
Make sure the car is out of gear.
B
r_towle
Dec 21 2003, 03:44 PM
cool...
I was trying to do it on a bare tranny...
I will try with a few BF pipe wrenches....
Rich
r_towle
Dec 27 2003, 05:04 PM
ok,
I tried a BF pipe wrench on both side and I get nowhere.
Can I remove the side plate and look for some part number???
I am thinking, remove the axle stub, then remove the ten or so bolts there....Will I have a whole bunch of parts fall out or am I safe doing this?
Rich
Bleyseng
Dec 27 2003, 06:28 PM
No, a whole bunch of parts won't fall out but alot of tranny fluid will if you don't drain it first!
It will be pretty obvious if its a stock unit of LSD if you then look.
Here is a stock unit pic of the diff.
Geoff
ChrisFoley
Dec 27 2003, 07:20 PM
What you probably have is a welded diff. When you open it up you will see welding between the gears inside the diff. It should be bronze welded.
r_towle
Dec 28 2003, 10:16 AM
Bleyseng,
So that piece comes out without removing the main shaft???
If so, I will remove and take a pic.
Thanx
Bleyseng
Dec 28 2003, 11:00 AM
No, you have to remove the gear stack to remove the diff.
Geoff
