QUOTE(Cap'n Krusty @ Aug 28 2007, 12:41 PM)
If the pressure and flow are within specs, such as they are in the L-jet pump, you can use an "inline" pump. I assume you mean "inline" to be a pump other than the original pump, which could also be considered to be "inline". You simply remove the "Y" fitting in the return line and substitute a straight through splice.
Remember, the adherence to the specs is REALLY important.
The Cap'n
If the flows are at or above stock. Pressure is regulated by the regulator. A stock pump will put out more that 29PSI if it's asked too. I've seen it put out 50PSI
I have an MSD pump that will put out enough flow and pressure for a 700HP motor works just fine.
