[quote name='rfuerst911sc' date='Sep 1 2007, 06:25 AM' post='941276']
[/quote]
I'm curious how are you going to tie into the rear shock towers on a street car? I'm thinking you have to go with bars thru the rear window? How do you maintain water intrusion protection? Trying to learn more. Thanks
[/quote]
First off, the rear window seldom gets wet....as I recall from the days I had one & went out in the rain.
A guy with a few fab skills could use a plexiglass rear window to seal it off......prolly not air tight, but close enuff.
The Engman kit stiffens the box structure around the passenger compartment....the front & rear box sections still flop around independently.
Draw your self a little picture that represents the 3 box structure of the 914 chassis or just look at the car with the doors off.
A tall box at either end joined by a long shallow box in between. The suspension is near the extreme ends of the tall boxes and where force is applied to the chassis.
Once you've done that, it's easy to see the weak points are and what needs to done to fix it. Simple to see, tough to fix. As I see it, it ain't worth the trouble for a street car.
