ztbell
Sep 1 2007, 03:14 PM
'75 2.0, speedo, clutch cable is melting, any ideas for insulation?
thanks for your advice...
Click to view attachment:
Sep 1 2007, 03:23 PM
QUOTE(ztbell @ Sep 1 2007, 01:14 PM)
are they routed correctly?
Andy
Cap'n Krusty
Sep 1 2007, 03:43 PM
Wrap 'em in some kind of heat resistant sleeve. Been a problem since the cars were new. The Cap'n
PRS914-6
Sep 1 2007, 04:01 PM
All my cables, fuel lines and oil lines are are installed with heat protection made by Goodridge.
Sep 1 2007, 04:05 PM
i had my headers ceramic coated inside/out ...
no heatshielding on the cables or oillines. so far, so good ...
Andy
pfierb
Sep 1 2007, 06:22 PM
QUOTE(PRS914-6 @ Sep 1 2007, 06:01 PM)
Click to view attachment Where did you get the stuff and what is it called?
Thanks Paul
ConeDodger
Sep 1 2007, 06:49 PM
QUOTE(ztbell @ Sep 1 2007, 02:14 PM)
In addition to the advice of others on insulation products, consider your timing. If your timing is off you can burn fuel in the exhaust greatly increasing the temperature in the area under the engine.
Allan
Sep 1 2007, 06:54 PM
QUOTE(pfierb @ Sep 1 2007, 04:22 PM)
iamchappy
Sep 1 2007, 07:34 PM
It's called fire sleeve. I use the orange Aeroquip stuff I think it's a little easier to source than the Goodridge hose.
ottox914
Sep 2 2007, 08:41 AM
Go to almost any auto parts store. They will have, or can get products to wrap lines to prevent heat-melting. I'm using on my clutch/speedo cables a section of heat wrap for a starter. Its long enough to go from about the engine mount bar to the clutch cable bracket where the pulley wheel is. It was to wide, so I wrapped it around the cables several times. The auto parts store also has some stainless steel tye wraps, which I purchased and used to secure the double wrapped heat barrier blanket thingy. I think I was out maybe 30-40 bucks for all of it, and have had no problems. Car is at a friends house for some turbo work, he's out of town, so no pics, but I'll gry to get a few next wk to add.
