mikeyboy_85
Sep 9 2007, 07:37 AM
Hey, i have an imported 914 and wanted to get the euro signals for the front to make the parker seperate from the turn signal.. and also the car handles not to bad but i think it could benifit from sway bars, could someone please tell me what brand to get etc and is installation hard?
skline
Sep 9 2007, 08:28 AM
Camp914 for the signal kit and as for sway bars, Weltmeister, stock or whatever you can afford. The installation is fairly easy on any of them.
So.Cal.914
Sep 9 2007, 08:30 AM
Camp 914, for the blinkers, you will see the ad above in the banner.
Sway bars will help. Performance Products, Automobile Atlanta for starters.
Installation is not bad, if you have Q's, you have come to the right place.
rhodyguy
Sep 9 2007, 08:57 AM
do you want oem or after market swaybars? good, used, complete, oem bars should be readily available thru the classifieds here, at narp, 914club, and pelican. new bushings and you're good to go. check your front control arms to make sure they have tabs for the droplinks.
k
mikeyboy_85
Sep 9 2007, 09:07 AM
QUOTE(rhodyguy @ Sep 9 2007, 06:57 AM)
k
well what would u suggest as the best option?? and what do these tabs look like ?? i really don't how a sway bar works. . . can someone explain it to me ??
rhodyguy
Sep 9 2007, 09:35 AM
the front bar passes thru the body under the fuel tank. you have to pull the tank to install it. the tab is pictured on the front control arms i removed from a car yesterday. you can see where the bottom of the droplink attaches in one picture and the top in the other.
k
So.Cal.914
Sep 9 2007, 11:16 AM
Like Skline mentioned, I run Weltweister and I have been happy, and the price is right. But you can spend more. It's a spring steel rod that runs from side to side, drop links tie the two sides together.
QUOTE(rhodyguy @ Sep 9 2007, 05:35 PM)
k
Here any pics
Click to view attachmentClick to view attachment
Rick_Eberle
Sep 9 2007, 03:57 PM
I converted the indicators myself. Just cut an aluminium plate to fit the indentations in the light housing, and drill a hole in the bottom to fit the light from the side marker. That will work as your parking light.
Where in Australia are you? I'm in Geelong.
mikeyboy_85
Sep 9 2007, 06:32 PM
QUOTE(Rick_Eberle @ Sep 9 2007, 01:57 PM)
Hey, Im out near lilydale, i would love to see your 914! Mine is the only one that i have seen in Oz
cheers michael
914-8
Sep 9 2007, 07:07 PM
QUOTE(Rick_Eberle @ Sep 9 2007, 02:57 PM)
Do you have any pics of your conversion? Not quite sure what you mean about "fitting the light from the side marker." The side marker light seems to be a part of the round plastic side marker assembly that can't easily be removed. Thanks!
John
Sep 9 2007, 07:46 PM
Mine are not like the factory made (the factory ones looked to be some sort of casting with a rounded reflector shape for the bulb.
Mine are made of 2 pieces of 1/8" plastic (maybe lexan). One piece is cut to fit in the housing and is curved on top to match the lens. It is used to block light from the rest of the housing. My second piece has two holes that sit on the locater pins that are part of the housing. This second piece is where I mounted a bulb socket. I bought bulb sockets and 5W bulbs at my flaps.
I made mine 19 or 20 years ago, shortly after buying my car.
mikeyboy_85
Sep 10 2007, 04:40 AM
here is my front end . . . i am told it has a 70's 911 front end, Would it effect me buying a 914 sway bar??
cheers michael
mikeyboy_85
Sep 10 2007, 04:43 AM
I take it that my car has not had sway bars installed ??
blitZ
Sep 10 2007, 06:40 AM
Looks like your car has never had a front sway bar. There is a good article at Pelican to show you how. However, there is already the tab on your A arm for the drop link, so it will be a little less work. It's a very worthwhile upgrade.
mikeyboy_85
Sep 10 2007, 07:43 AM
QUOTE(DEC @ Sep 9 2007, 11:52 AM)
what kind of sway is this ?
rhodyguy
Sep 10 2007, 07:48 AM
oem with what appears to be fresh anodizing. real sharp!
k
mikeyboy_85
Sep 10 2007, 09:49 PM
What are the advantages of the Weltweister? i was looking at them in pelican and they seem well priced, i also say the rear OEM one as well. Is there any complete kits for the rear cause i noticed that the rear sway brackets are no longer availble?
thanks michael
Rick_Eberle
Sep 11 2007, 10:41 PM
QUOTE(914-8 @ Sep 10 2007, 11:07 AM)
Actually, when I really think about it, it was only the wiring that got used...
I switched to H4 headlights, and they had an optional parking light socket, and I put that into the bottom of the indicator housing.
Rick_Eberle
Sep 11 2007, 10:49 PM
QUOTE(mikeyboy_85 @ Sep 10 2007, 10:32 AM)
cheers michael
Your on... I got mine registered in July, and it's my daily driver now. I'd like to get up to Healesville Sanctary one of these days. I'll send you a PM in a couple of weeks.
