rufio0205
Sep 13 2007, 07:05 PM
any suggestions on which cd player would be a good fit for a 73 914
scotty b
Sep 13 2007, 07:18 PM
Any in dash will require the dash to be cut ( if it isn't already) otherethan that you could use a remote changer with an original "looking" ( knobs ) aftermarket radio with changer controls
firstknight13
Sep 13 2007, 11:36 PM
i fit mine in NO problem of course it is ALPINE............
thomasotten
Sep 14 2007, 06:54 PM
I didn't cut mine.
familienauto
Sep 14 2007, 08:09 PM
Anybody care to offer a model name/number for a CD player that fits? I'm about to order one too.
Zach
robby750
Sep 14 2007, 08:14 PM
QUOTE(familienauto @ Sep 14 2007, 09:09 PM)
Zach
Here is a Sony, don't know the Model # but it did not require any cutting. About $129.00 at Circuit City.
scotty b
Sep 14 2007, 08:23 PM
Yeah I fudge up and wasn't thikning straight. I forgot teener have that nifty cover plate for the knob radios. Damn I need to get back to werk on my dads car......
stateofidleness
Sep 14 2007, 09:14 PM
pretty sure they're all "standard" size.
just make sure it's a SINGLE din and not a DOUBLE din spacing and you should be fine.
most aftermarket headunits are SINGLE din and should fit just fine.
what im curious about though is how you wire up a modern headunit to a porsche... seems like mine only has an antenna wire behind it.. am i missing something?
familienauto
Sep 14 2007, 09:19 PM
When I pulled out the "Masu" el-cheapo cassette player that was in the 914, I found the antenna wire, a power connection (12 V I suppose? I didn't measure), speaker wires, and a ground wire. Not sure what's stock, but that's what was there.
rufio0205
Sep 26 2007, 09:11 AM
my 914 didnt come with a stereo at all. no radio nothing. no speakers. got speaker covers but no speakers. any ideas on how to wire it. because i have a cunning way to fit my player in. just need to make custom brackets and such
thomas
Dave_Darling
Sep 26 2007, 10:36 AM
Hook a wire to the fuse panel for +12V. You should be able to find one "switched" power and one "contant" power there. Ground anywhere. Run speaker wires from the speaker locations to the amp or head unit location. Hook up the antenna. That's pretty much all you need, unless you're going with other bits like a power antenna or external amp.
--DD
