HalM
Sep 14 2007, 05:49 PM
I need to use my floor jack and remove my wheels. The normal jack tubes are rusted out and due to be replaced shortly. In the interim, where under the car can I place the jack and not hurt anything?
Thanks,
Hal Michael
'73 914 2056 RAT
'96 993
RoninEclipse2G
Sep 14 2007, 07:00 PM
Unfortunatly I don't have acess to a cam to take pics, but there's a round opening just under the side near the jack point that works great.
swl
Sep 14 2007, 07:15 PM
just be careful with the jacking donuts - they can be rusty too. Listen for any crunchyness as you are lifting. If you hear anything put her back down and look for alternatives. The rear donut is pretty close to the fore and aft balance point so you are going to be lifting pretty much the entire side of the car. Heavy.
orthobiz
Sep 14 2007, 11:25 PM
Found some pics where I have jacked and supported my car: the hydraulic jacks are using the donuts in the front. I used stands on the torsion bar supports, but I guess you could jack there as well.
Oh yeah, got rid of my ratchet style stands in favor of the pin style thanks to Gint!
Paul
swl
Sep 15 2007, 06:39 AM
OK - confession time. Looking for a slap if this is stupid.
Since I was nervous about lifting rear using the donuts (had one start to collapse) I tried lifting the entire rear by the end of the tranny. My thought was that the lift is being transmitted straight up the tranny mounts into the reinforcement of the frame. I then put the jack stands on the trailing arms at the front. That part I'm comfortable with but am I risking damage to the tranny?
HalM
Sep 15 2007, 06:44 AM
Thanks for the help everyone. Much appreciated!
Hal
So.Cal.914
Sep 15 2007, 06:55 AM
Probably a good idea.
thomasotten
Sep 15 2007, 07:15 AM
Jacking by the tranny or engine can cause the rubber mounts to rip.
RoninEclipse2G
Sep 15 2007, 09:17 AM
QUOTE(swl @ Sep 14 2007, 07:15 PM)
Oh yeah, I forgot about that, sometimes I forget these cars have rust issues
I'm proud to have a practically rust free unrestored car, only had a problem with the drivers side outer rocker cause a PO went offroading and caught a bunch of dirt up in there
Mountain914
Sep 15 2007, 11:19 PM
Does this help ? I think I got it from Damp Dave, but can't remember which post or where.
Dave_Darling
Sep 16 2007, 01:59 PM
On those long areas, make sure you use a board to spread the load out over a large area.
The circles are quite reinforced and can hold the car up without anything to spread the load.
--DD
