QUOTE(Bartlett 914 @ Sep 15 2007, 03:46 PM)
It means taking all measures to stop oil leaks like push rod tube seals, valve cover seals etc. The air guides also need to be sealed to stop wasting cooling air. Around the spark plugs (for example) there is a rubber boot between the spark plug insulator and the engine tin. There are a number of holes in the engine tin that likewise need to be plugged.
OK, given the fact that all engines should be 'sealed' (isn't that why you run it on an engine stand before you drop it in?) I will make an educated assumption that it becomes more important in a 914 based on its open air configuration. Is this an accurate statement?
When I completely overhauled the engine on my now sold 78 MG I checked all the seals for leaks before installing it into the car; I didn't have to worry about rain getting on like the 914.
So, other than the obvious things, is there anything in particular that I should pay attention to with the 914 that I might not otherwise consider with a fully enclosed water cooled power plant?
