I know there is info here on this, but a search didn't turn up much. Little back ground here, I picked up a complete 74 911 with 2.7 for $300 last month. My two year plan was to do a 5 lug swap using this 911 and then /6 conversion, but after reading Chuck's thread on /6 motor selections and Conedodger's thread on his 2270 build it has me rethinking my plan a little.
Here is what I want from my 914. A great AX car that I can drive on the street from time to time. Must have heat, so need heat exchangers. Now all I know about the 2.7 I have now is that will turnover, but I haven't done a compression check yet. So it might need a rebuild $$$$$ But lets just assume it doesn't, but it will need a good once over.
Not counting the 5 lug stuff, just parts needed for a /6 I would need the following:
/6 engine (got that, but Chucks thread has me wondring if a 2.7 is a good idea)
/6 carbs (If I didn't stay CIS)..... $2000
/ 6 engine mount ( looking at Rich Johnsons setup) ~$500
complete oil tank, filler next, dip stick..... ~1500
/ 6 heat exchangers (I know, I know) .....~$1500 - $2500 ish
/ 6 Muffler........$??? ($250 - $400???)
/ 6 engine tin ......$??? ($300??)
Front oil cooler and lines.......$???? ($250???)
Misc engine work (tune up, FI cleaned...) $1000
Labor for stuff I can't do (welding, mis install stuff) $1500
Please tell me if my numbers are off or if I have missed anything. Using the lower end of these numbers I'm looking at around $8800. Now if the 2.7 needs more than just a tune up, YIKES!!!!!
I haven't talked with Jake yet, but based on his website it looks I would be in for around $8.5k for the turnkey 2270 motor I would want.
What I like about the big 4 is I don't need to do any of the above in order to install it. And from what I read I would have the same amount of power as a 2.7 /6
Please don't turn this into a big 4 vs /6 thread, I just really want to get my numbers as close to real as possible on the /6 stuff. Once I get that then I will contact Jake on the big costs.
My AX weapon
The donor
