Mueller
Dec 24 2003, 01:34 AM
After reading Redshifts post about his cables, I thought a list of tools needed and recommended while owning and maintaining a 914 would be a good idea....
Maybe once the thread is dead, we can add the list to a FAQ (which most lazy @ss people don't read or look for, LOL)
jack (aluminum optional)
jack stands (one pair minimum, or if you are like me, you need at least 3 pair......4 jacks for your 914 and the other 2 for your "running" cars)
Metric tool set (sockets, wrench set)
3# sledge hammer BFH optional (IMHO, a claw or woodworker type hammer should never be used near a car)
small inspection mirror
small bright flashlight
triple square drive set(for CV joints)
Metric allen wrench set(shifter assembly, front suspension skid protectors.....)
torque wrench(1/4" drive In-Lb, 3/8" and 1/2" Ft-Lb)
smrz914
Dec 24 2003, 01:44 AM
May want to have:
wire cutters
crimpers
an assortment of connectors (male, female, etc.)
multimeter (either an automotive one that has dwell or a standard one)
Dec 24 2003, 01:56 AM
a case of brake cleaner
stock93
Dec 24 2003, 02:12 AM
How about
Socket driven allens
feeler guages(points, valves, brakes, etc)
I'm sure theres more I'm just not thinking of any right now.
John
sj914
Dec 24 2003, 02:35 AM
Breaker Bar
5ft. pipe(cheater bar)
Torch
angle grinders
MIG welder
URY914
Dec 24 2003, 05:47 AM
I use screwdrivers a lot on my car.
RON S.
Dec 24 2003, 05:51 AM
My most used is my Dremel & pneumatic die grinder.
Ron
Curvie Roadlover
Dec 24 2003, 05:54 AM
17 mm Allen wrench for the tranny plugs.
HarveyH
Dec 24 2003, 06:27 AM
Reference material: manuals, parts lists, and print-outs of internet material.
Beverage of choice
Merry Christmas and Happy New Year to all.
Harvey
DuckRyder
Dec 24 2003, 06:42 AM
Heads - the more the better.
OH, tools, A big ass pair of channel locks................. Why do they call one plier a "pair"? Inquiring minds wnat to know...........................
URY914
Dec 24 2003, 06:43 AM
How about a lap top and a wireless net connection in the garage. And a d-camera to up load pics to this site when you have a question.
This website is the best tool in the box.
Paul
morgan
Dec 24 2003, 07:15 AM
A second 914
ejm
Dec 24 2003, 07:28 AM
Large color wiring diagrams and a test light
Curvie Roadlover
Dec 24 2003, 07:37 AM
QUOTE(URY914 @ Dec 24 2003, 04:43 AM)
Paul
Rusty
Dec 24 2003, 07:39 AM
Needed:
Brake bleeding kit
Recommended:
Fuel pressure gauge
Carb synchrometer (if appropriate)
DNHunt
Dec 24 2003, 08:09 AM
Not really tools but these help
Pet CD
Lots of rags
gloves
friends with lots of parts
an extra car to go get the parts
fat wallet (soon to get much skinnier)
Dave
Merry Christmas and Happy Holidays
Gint
Dec 24 2003, 08:17 AM
THREE cases of brake cleaner. When you get down to one, that's when you re-order.
JeffBowlsby
Dec 24 2003, 09:29 AM
An multimeter to sort out the FI.
Black Chrome for the exterior rubber parts.
A spring type oil filter wrench.
AZ914
Dec 24 2003, 09:40 AM
I found I needed FLARE WRENCHES to do my brake work.... The PIPE WRENCH came in handy a couple of times...
brant
SAWZALL ?
ha..
brant
Bruce Allert
Dec 24 2003, 09:53 AM
a liv-in "competent" 914 mechanic (key word-competent)
maf914
Dec 24 2003, 09:57 AM
Special Porsche tool for ball joint slotted lock nut, also known as a BA pipe wrench!
Or borrow Dave's custom made galvanized pipe facsimile!
Mike
Also, keep a philips head srew driver in the glovebox to adjust and refasten the sunvisor hardware after they work loose and the visor falls off.
scotty
Dec 24 2003, 10:31 AM
All of the above plus...
patience! When it won't work, sit back, stare at it, consult with fiends, have a beverage,
then go at it again!
Repeat as needed...THEN get the BFH/sawzall/dremel/torch and beat/cut/grind/melt it to death (after locating replacement parts)
Aaron Cox
Dec 24 2003, 10:57 AM
elbow grease....
Malmz
Dec 24 2003, 11:11 AM
Socket for Steering wheel nut
Socket for Axel nuts
23mm and 27mm??? I forget...
Super Sawzall Plus. I can't believe Mueller of all people missed that... Brant picked up the slack though...
Skinny 11mm wrench as well as a regular 11mm for clutch cable adjustments.
Por15...
PB Blaster penetrating oil.
Computer in the garage so the SO doesn't see you walk in all greasy.
Fridge full of cold beverages in the garage.
Urinal or low sink in the garage or neighbors who don't mind you peeing on the trees...
sm
boxstr
A tow dolly or trailer.
CCLINTOWTOWN
Aaron Cox
Dec 24 2003, 11:17 AM
BEER!
VegasRacer
Dec 24 2003, 11:21 AM
I've never had a weekend at the track where I didn't use zip-ties or duct tape for something.
L8Apex
Dec 24 2003, 11:29 AM
YOu gotta have vice grips.
garyh
Dec 24 2003, 11:59 AM
QUOTE(scotty @ Dec 24 2003, 08:31 AM)
consult with fiends
Best advice ever.
Eric_Shea
Dec 24 2003, 12:12 PM
MAP Torch... most invaluable!
Air_Cooled_Nut
Dec 24 2003, 12:31 PM
Absolutely necessary:
Shop manual
kdfoust
Dec 24 2003, 01:10 PM
Impact wrench.
watsonrx13
Dec 24 2003, 01:32 PM
A close friend when you need a 'third' hand. And of course this web site and shop manual.
Qarl
Dec 24 2003, 03:11 PM
Bead blasting cabinet or access to one. Seriously... you don't know what you are missing!
Qarl
Brad's cell phone number
Eric_Shea
Dec 24 2003, 04:10 PM
This...
TROJANMAN
May 25 2006, 10:54 AM
PB blaster and a 12 pt CV tool
dug up this thread looking for something else
seems a bit classic
lapuwali
May 25 2006, 11:00 AM
It will be an FAQ, as Mike suggested at the top...
jhadler
Eric beat me to it... I'm surprised it didn't get mentioned before. Oh, and don't forget the AAA card as well...
-Josh2
rhodyguy
May 25 2006, 11:11 AM
30mm, 1/2", impact socket.
fi cars ignore, a couple of small (i mean small) screwdrivers and a can of compressed air.
a set of the lesser quality pneumatic tools from costco and a 25 gal portable compressor.
a good flashlight with extra bats.
cat litter.
k
k
TROJANMAN
May 25 2006, 11:31 AM
directions to Gint's house
zymurgist
May 25 2006, 11:48 AM
QUOTE(Malmz @ Dec 24 2003, 01:11 PM)
That's exactly what the evergreen right outside my garage front door is for! It keeps its foliage year-round so nobody can see what I'm up to...
grantsfo
May 25 2006, 12:19 PM
Dont forget the jack plate for that floor jack.
Sideways
May 25 2006, 08:03 PM
100 cases of Beer...
99 to be consumed while working on the car
1 to enjoy when the work is done...
Joe Bob
May 25 2006, 08:15 PM
AAA GOLD RV DELUXE OLDPHART Card with 100 mile tow option....get one for the wife so you can use her tows when ya runs out....
GWN7
May 25 2006, 09:02 PM
every 914 owner will need one of these sooner or later....I got one today...
computers4kids
May 25 2006, 10:12 PM
Every 914 owner should have...
nycchef
May 26 2006, 05:28 AM
several credit cards with really high limits
