Chuck
Sep 18 2007, 07:22 PM
I'm curious if anyone here has ever put some sort of electric heater into their 914. 914-6 heat exchangers, or equivalent, are $1500+. A header can be had for $400 and increases performance.
I can live without heat per se, but I will really need a defog option in my car for rainy days. Anyone rigged something up? Care to share?
ConeDodger
Sep 18 2007, 07:27 PM
QUOTE(Chuck @ Sep 18 2007, 06:22 PM)
I can live without heat per se, but I will really need a defrost option in my car. Anyone rigged something up? Care to share?
Chuck,
I have heard of but never seen anyone do the VW gas heater thing... Some headers do come with heat exchanger for 4 cylinders. Not sure about sixes. If you really are just looking for a good functional street car, you can go with SSI heat exchangers instead of headers. Great performance and great heat. In Minnesota you would need at the least a defroster as the windows go fog city with the slightest touch of rain combined with closed windows and breathing occupants.
PeeGreen 914
Sep 18 2007, 07:29 PM
A really big Jacket
I just use the rain-x no fog on the inside and rain-x on the outside. I have yet had a problem with it fogging up on me. I have no heat or blower motor anymore. It doesnt get as cold here as it does there though. I don't really drive it in the pouring rain either.
swl
Sep 18 2007, 07:35 PM
Chuck. My daily driver is a smart car - super efficient little diesel but so little waste heat that it is pretty cold in the winter. They have a little electric heater that cuts in as a booster but it really doesn't do a lot. Might take the mist off the windscreen on a cool day but I wouldn't hold out a lot of hope for it.
There was a gas heater available on the original bugs that would probably be a better answer. Mind you they had a bad rep for fires.
I seem to remember the guys on the smart forum talking about an auxilary heater from across the pond. I'll do a search and see what I can find.
PeeGreen 914
Sep 18 2007, 08:05 PM
QUOTE(swl @ Sep 18 2007, 06:35 PM)
Why would that be bad
It could be interesting to hear about the other heaters though.
jd74914
Sep 18 2007, 08:08 PM
I thought they were actually pretty safe? Anyways, I think the big company was Wabaso? or something like that
swl
Sep 18 2007, 08:13 PM
lol - searching for heater on the smart board brings back about 900 hits. Sort of searching for 'rust' here. I've posted a request - see if anyones memory is better than mine
Grelber
Sep 18 2007, 08:42 PM
Put two 12 volt hair blow dryers in the front trunk, duct taped to your defroster vents.
alpha434
Sep 18 2007, 08:48 PM
Eberspacher.
Check both the Samba and your FLVWPs (That's friendly local VW Parts)
A rebuilt unit can be had for 450 here in Colorado in the summer. I assume demand goes up in the winter-> prices up.
Wannabe 914-6 owner
Sep 18 2007, 09:03 PM
Seems like JC Whitney used to offer a gas heater sytem for bugs. Don't know if they are still in business?
Dr Evil
The Corvair also had a reliable gas heater that may be available for less.
sww914
Sep 18 2007, 09:06 PM
Gas heaters are all over thesamba for $100.00-$200.00.
Chuck
Sep 18 2007, 09:15 PM
[/quote]
[/quote]
That is EXACTLY what I am trying to avoid. I may just need to bite the bullet and spend the $$ on the SSIs.
swl
Sep 18 2007, 09:24 PM
forget the smart heater. Diesel fuel (duh!), heats the coolant and costs $2400!!!!
Chuck
Sep 18 2007, 09:55 PM
QUOTE(Grelber @ Sep 18 2007, 06:42 PM)
After the day I've had, that sounds like a helluva good idea. Simple, effective, inexpensive.
rktmn247
Sep 18 2007, 11:24 PM
I am from MN. and when visiting my family one winter, had the heater core in my camaro fail. 55 mph in 20 below weather. Imho there is no way a couple of hair dryers would get the job done. Although, with this global warming I could be wrong.
VaccaRabite
Sep 19 2007, 07:35 AM
QUOTE(rktmn247 @ Sep 19 2007, 01:24 AM)
When it gets that cold,your 914 should be parked - heat or no heat! Use your beater, and save the 914 for nicer days.
Zach
Chuck
Sep 19 2007, 12:27 PM
QUOTE(rktmn247 @ Sep 18 2007, 09:24 PM)
You misunderstand. My car will only be taken out once the salt is off the roads in the spring and will be put away by November. But, I would still like to be able to drive it on rainy days and around here, that means defrost.
John
Sep 19 2007, 12:42 PM
I know that they make small square space heaters that sit under a desk and plug into the wall. I have seen many in offices where the desk jockey gets cold.
You may be able to power one of those with an inverter to warm up the cabin.
Where does the defroster air get returned to the blower? Duct the heater there and you would get heat out of the defrost vents.
JC Whitney (yes they are still in business) used to sell a 12v heater that was essentially a hair drier mounted in a different plastic case and could be used as a defroster. They were ugly and bulky, but with a creative mind and some work, I'm sure it could be modified to provide heat to the blower plenum.
I think in the end, it may be easier to simply put a box around a set of headers and blow air through the box. That is the basic concept of the stock heat exchangers.
Good luck with your project.
davep
Sep 19 2007, 01:09 PM
No electric heater will work effectively, the alternator cannot supply enough power!
SSI heater boxes along with a functional stock heating system both works effectively and is cost effective with all alternatives I know about.
rktmn247
Sep 19 2007, 01:43 PM
QUOTE(Chuck @ Sep 19 2007, 07:27 AM)
Roger that. I also do not have heat and think, even here, I might need defog if I were to get caught in the rain; but then I would have to drive the car for that to happen.
Rand
Sep 19 2007, 03:11 PM
Forget electric. One that would actually work takes more power than you can supply in a car.
They make little units you can throw on your dash that almost work for a defroster (
like this one) but they will make your stock wiring dangerously hot in 15 minutes and don't do much. Making real heat from car electricity is out of the question.
The gas heaters work (Eberspacher, Webasto, etc). If they are installed and maintained properly, they are safe and reliable. There are several threads around here about them, so a search will turn up the info.
If you want a ridiculously simple solution for occasional heat, look into a
Coleman golf cart heater. Drop it in a cupholder, or make a simple dash mount that lets you rotate it to aim at you or the windshield. (I know, not an elegant solution. But I am going to headers, rarely need heat, and like to keep my 914 as simple and light as possible, so it works for me.)
racunniff
Sep 19 2007, 10:10 PM
QUOTE(Rand @ Sep 19 2007, 02:11 PM)
I'm putting an electric heater in mine:
http://www.canev.com/KitsComp/Components/Heater.htmlBut I have 1200 pounds of batteries to draw from
http://volt914.blogspot.com/2007/07/144v-p...s-charging.html
alpha434
Sep 19 2007, 10:31 PM
QUOTE(Rand @ Sep 19 2007, 03:11 PM)
Where does the carbon monoxide go?
IronHillRestorations
Sep 19 2007, 10:54 PM
I got a very near NOS Webasto, originally for a 356. I was going to make it work in a 914, still have it, but I won't be doing that proj any time soon.
boxstr
Sep 19 2007, 10:57 PM
How about seat heaters?? CAMP 914 sells them.
CCLINHOTBUNS
Chuck
Sep 19 2007, 11:20 PM
QUOTE(boxstr @ Sep 19 2007, 08:57 PM)
CCLINHOTBUNS
I need to keep the windshield defogged when rainy. I can actually live w/o heat in the car except for that. Just hate to pay $1,000 more for heat exchangers versus headers just for that.
Rand
Sep 19 2007, 11:35 PM
QUOTE(alpha434 @ Sep 19 2007, 09:31 PM)
Not all heaters produce dangerous levels of carbon monoxide.
Here is another one using the same design that is "Designed for indoor use."
The one thing you DO have to pay attention to however is: They consume oxygen. My 914 isn't so air-tight that it's a problem on my short morning commutes. But if you were going on a long drive you should crack a window.
alpha434
I was serious... Where does the exhaust go? I might like that device- unless it shouldn't be used in a confined space...
Bartlett 914
Sep 20 2007, 08:12 AM
QUOTE(alpha434 @ Sep 19 2007, 09:35 PM)
In order to be safe for use inside, it would need a catalytic converter. Another problem is with propane a lot of moisture is generated which won't help defogging of the windshield.
Zundfolge
Sep 20 2007, 09:43 AM
QUOTE(Chuck @ Sep 19 2007, 11:20 PM)
Honestly NO heater/defroster is better than a weak one.
My 914 has headers so no heat for me, but I found that I could keep the windows from fogging up on the inside by keeping the window cracked an inch or so ... sure it makes the interior colder, but bundle up and you'll be fine.
As for keeping the windshield
defrosted ... there's a long list of reasons not to take the teener out in the ice and snow.
EyeTrip
Sep 20 2007, 10:09 AM
I don't know how much room you have with a 6, but is there any way you could rig up an external oil cooler with a fan and pipe it into the heater ducts?
VaccaRabite
Sep 20 2007, 10:17 AM
If you are just concerned about windshield fogging, and not about actual heat, give any of the anti-fog compounds a try. Rain-X makes one that has been mentioned in the thread. There are several others in the market as well. The stuff has been around for quite a while, I used to use it to keep my paintball mask from fogging (before anti-fog masks became popular, as I said, its been about 15 years).
I'll be appling some sort of anti-fog to my 914 once it become drivable (also no heat), and lots of regular old rain-x on the outside too - the stuff makes a night and day difference if you get caught in a storm, you almost don't need wipers.
Zach
marks914
Sep 20 2007, 10:40 AM
My setup would probably work, it will be available in a few weeks
Mark
Check out my website for mor info
VaccaRabite
Sep 20 2007, 10:48 AM
QUOTE(marks914 @ Sep 20 2007, 12:40 PM)
Mark
If the car in question is a water-pumper. Which most of our cars are not.
Looks like a slick solution though, if you are. Does it actually scavenge enough heat to work?
Zach
stephenaki
Sep 20 2007, 02:15 PM
QUOTE(davep @ Sep 19 2007, 11:09 AM)
Funny this topic should come up, just asked the owner of the 914 I just bought whether or not the car had heat or not! Since I will pick it up probably in November and be driving through the Austrian Alps on my way home, heat would be nice!
Anyone know how big of a job it would be to swap out the headers for the SSI set up? I may have to do that before I hit the road after I pick up the car if I find out that there is no heat for the ride.
Rand
Sep 20 2007, 02:21 PM
QUOTE(alpha434 @ Sep 19 2007, 10:35 PM)
It's catalytic and safe for indoor use. Not enough exhaust / carbon monoxide to worry about. It can be used in a confined space (unless you're planning on sleeping with it in an airtight box). Crack a window if you're inside long enough to worry about it using up your oxygen. My car isn't that air tight. Not an issue.
tdgray
Sep 20 2007, 02:30 PM
Why reinvent the wheel
Just use the VW gas heater. Very safe if used correctly and IIRC the thing puts out MASSIVE amounts of heat.
GeorgeRud
Sep 20 2007, 02:38 PM
I bought an Eberspacher gasoline fired heater off eBay last year, and was planning to mount it and use it for heating. I fired it up on the bench and it puts out tons of heat.
There were pictures floating around of one mounted in the front trunk of a 914, looked like a factory deal. I never got around to the project, and found a good set of used heat exchangers, so I shelved the project. It should work if someone just tries to follow what the factory did. You can also follow the ideas that Porsche used in the early 911s, as they also had these available as an option.
Chuck
Sep 20 2007, 03:07 PM
QUOTE(Zundfolge @ Sep 20 2007, 07:43 AM)
Yep, I miswrote when I wrote defroster - meant to write defogger. My car will NOT see ice, snow or salt when it is done!!
marks914
Sep 21 2007, 01:41 AM
QUOTE(Vacca Rabite @ Sep 20 2007, 08:48 AM)
Mark
Zach
You have to run oil through there instead of water
Mark
Brian Mifsud
Sep 21 2007, 11:37 AM
If I was going to rely on electric heating, I'd first put a heater into the seats for personal comfort.
Defrost vs Defog is another animal. Of course you need some high heat and very fast air flow to melt any ice. You might consider an electric heating element in the airbox, but I'd make darn sure that the fan MUST be activated before current is allowed to flow to the heating elements.. so a "lockout" of some sort is in order.
Defoggig really requires dry air. Either you "superheat" humid air, or you put in an AC system and heat the dried air before blasting the windshield (much like most cars built after the mid-80s do).
I believe though, that after adding up all the costs, it might just be a "push" to have a fabricator weld up some custom boxes around your new headers for a much simpler and conventional system.
Chuck
Sep 21 2007, 12:38 PM
[/quote]
I was reading the classi thread that Dan (Root Werks) had put together on his 6 conversion. He used Bursch headers and fabbed a heater setup off of thos. That looks like a nice solution.
Eddie914
Sep 21 2007, 08:26 PM
I installed one of these:
http://www.autobarn.net/3000c.htmlI know it doesn't get very cold in Seattle but it's a lot better than nothing.
Eddie
