QUOTE(John @ Sep 21 2007, 07:36 PM)
Fenders, door skins, replacement panels and most of the rest of the car is definitely NOT 18 ga. The car would be very heavy if it were. 20 ga maybe, but not 18 ga.
Paper is way way thinner than 22ga steel.
The difference between 20 and 22 ga is only .006"
Here are some thicknesses and weights:
24 ga. = .024" = 1.000 lb/sq. ft
22 ga. = .030" = 1.250 lb/sq. ft
20 ga. = .036" = 1.500 lb/sq. ft
18 ga. = .048" = 2.000 lb/sq. ft
16 ga. = .060" = 2.500 lb/sq. ft
14 ga. = .075" = 3.125 lb/sq. ft
12 ga. = .105" = 4.375 lb/sq. ft
11 ga. = .120" = 5.000 lb/sq. ft
10 ga. = .134" = 5.625 lb/sq. ft
Most anything over 10 ga. is extreme overkill on a car.
For reinforcement, you can use heavier steel if you like....
I just measured the sheetmetal in the tunnel it is about .020". Couldnt get to the firewall but thr mangled part by my clutch tube looks to be about double that so I'd guess 20ga.
Paper is .003" FYI
