QUOTE(RohJay @ Sep 20 2007, 02:35 PM)
I have a non running car on which I am about to do a carb conversion.
Currently the Engine Realy Board is empty, except for the Alternator Regulator.
Which Relays are required? (I presume Fuel Pump is one.)
and are all relays identical?
Thanks
R
It depends on what you want. See this article for information on
how to hook up the fuel pump:
Fuel Pump Wiring for CarbsIn the pictures of the relay board there are 2 unlabeled relays.
The relay towards the top offset slightly to the left, is for the optional rear window defogger.
The relay at the bottom is for the heater fan.
Hope that gets you started.
--- bill
