mike souza
Sep 20 2007, 04:35 PM
So I"ve burned out 2 head temp sensors in the last month, & I'm thinking it may be a grounding issue, so I jacked the car up (was told the ground strap would be visible between the transaxle/body) & didn't find it.
so does anyone have more detailed directions/ pictures for a newb?
oh & its a stock 75 1.8 btw
thanks!!!
sww914
Sep 20 2007, 04:40 PM
It's a piece of flat braided wire, uninsulated, that runs from the back of the transaxle on the driver's side, straight up to an 8mm stud on the floor of the rear trunk. Some have been changed, mine is a piece of 2/0 gauge welder wire with eyelets on either end.
Rand
Sep 20 2007, 06:56 PM
No pic, but mine is easily visible by looking behind the driver's side rear tire for what sww914 described.
Kirmizi
Sep 20 2007, 10:24 PM
That ground strap is pretty obvious and if it is missing, well you may want to inspect your throttle and clutch cables too since they will act as a "ground" in it's absence. Mike
mike souza
Sep 21 2007, 01:16 AM
ok, I'll check it out as soon as I wake up tomorrow!
thanks a lot guys, I really apreciate the help!
watsonrx13
Sep 21 2007, 04:59 AM
Here's a pic of the tranny ground strap...
-- Rob
Cevan
Sep 21 2007, 08:45 AM
Resized for better viewing:
mike souza
Sep 24 2007, 02:56 AM
OK! sweet!
so I checked the strap, its there but in horrible shape.
I went to kragen, bought a 15 inch battery lead & put another ground further up, closer to the battery (From the front of the engine to the pass. side crossbar)
I'm going to Fibrecraft racing tomorrow to pick up a new stock ground strap as well.
its nice, the thing actually IDLES now!!!
...man I hate electrons
thanks for all your help!
