JOE M
Sep 21 2007, 11:30 AM
When I turn my key aux. the fuel pump makes a loud ticking noise. I can also hear it when the car is running. Is it a bad pump or could it be a faulty ground. The ground is tied back to the bracket the pump is mounted to ( rusty bracket). Or is this normal for this type of solid state type of pump. 1972 914 with carbs.
Thanks
Cano
Sep 21 2007, 11:49 AM
When I was still running a carb, my facet fuel pump made a similiar noise, but always worked fine. I think it is just the nature of the beast.
rhodyguy
Sep 21 2007, 11:55 AM
does it look similar to this one? they're noisy by nature. if the mount backet is fastened directly to the chassis, metal to metal, you can lesson the racket by isolating the mounting point with a piece of rubber. keep the ground clean.
k
JOE M
Sep 21 2007, 12:42 PM
QUOTE(rhodyguy @ Sep 21 2007, 09:55 AM)
k
Looks almost identical. it is on rubber isolaters but is still loud. sounds like it might be o.k no pun.
purple
Sep 21 2007, 01:36 PM
i had one and it jammed.
replaced it with a cb rotary and never looked back. now all i have is a low hum
it would have helped if the rust from the tank didnt get into the pump, the p.o. put the fuel filter AFTER the pump, with no strainer in the tank
