QUOTE(Roy @ Sep 21 2007, 02:18 PM)
Hi everyone, I'm new around here and first off would like to thank everyone for the wealth of knowledge available on this great forum! I am having a problem with my new to me '73 2.0. I have a dead #3 pot. I have verified I have spark, a good fuel injector and about 130 psi compression. I have not yet checked the valve clearances. Could I have good compression and all other requirements and still have a dead hole? In searching old posts it seems like too tight a valve clearance could cause this problem, but would that not affect my compression test results negatively? I also think I read Jake say that if it is #3 it is more likely than the other cylinders to be adjusted wrong. Did I understand him correctly and if so why is that? Thanks for all responses!
If you know that the injector is firing gasoline, the spark is getting to the plug tip and sparking, you could have a bad rebuilt injector, an intake leak, or tight valves.
