QUOTE(Dr Evil @ Sep 21 2007, 02:34 PM)
Well, thanks to Matt (Plas76targa) I have my timing problem solved as he lent me his perma-tune while I am waiting for a replacement CDI box. I adjusted the idle stop screw and that fixed the crappy idle. And I have the fuel adjusted pretty close to perfect so far as I can tell (I went as lean as it could stand and richened it a little). I will get the shop down the street to use the CO meter to fine tune it later.
After all this it runs much better, can go to 6k parked (I'll road test it tonight), and idles just fine, BUT it still backfires out of the tail pipe when I hold the RPMs up a little. No fuel adjustment seems to affect this, and there seems to be sufficient power. Addition of the perma-tune has curbed the backfiring significantly, but it is still happening.
What might be causing my backfire?
I'm assuming that this is a 2.7L 6 cyliner with CIS?
If so, you are way too lean. CIS will run incredibly lean, dangerously lean. Lean CIS revs very quickly and willingly. (You can't adjust it like a carb, leaning it until its rough then richening it up.) You need to richen it up, clockwise slowly on the adjustment screw, 3mm by fuel distributor. When you are too rich, the idle will surge up and down. I would richen it a little at a time, approximately 1/8 turn, until the backfire goes away.
Also, you should not ever need to adjust the idle stop screw. With CIS you use the large air by pass screw on the side of the throttle body to adjust air bleed (controlled vacuum leak) to set idle speed. You need to adjust both the air by pass and the mixture(3mm) to get the idle speed and mixture right.
Good luck,
Ed
