QUOTE(TedK @ Sep 22 2007, 10:47 AM)
Hey Paul, if you don't use the "bag" I would do the following:
1- Lay a good plastic tarp on the floor to park on and prevent moisture uptake.
2- Spread rodent poison is mass quantities around the perimeter of the floor.
those light green pellets work good for me on mice, rats.
3- Check out West Marine or some other boating suppply for those re-usable
moisture absorbing bags to place in the interior. I think you just heat them
in the oven to remove moisture and re-use.
Cheers
Ted K
+1...
Absolutely the way to go! The rodents will always eat the poison before they eat the car, and once they gorge on the poison, they will seek water, so make sure you don't leave a water source in the barn. They then exit, and die outside, where they belong.
Sealing the building, or the car, is a virtual impossibility to prevent rodents infestation... mice can enter thru a hole less than 1/2 inch, and if no hole, they will chew their way thru everything up to 1/4 inch steel plate! If the bag or cover is of plastic or any organic material, they will chew thru that just to see what is inside!
Cats don't work so well, since they have to have a source of water, and they won't survive all winter on the rodent population, so you will have a dead cat come spring, and still have the rodent problem!
I also spread a number of dryer laundry softener sheets around the perimeter of the car, and put one in any obvious opening (tailpipe, etc.) I hold them down with the boxes of rodent poison! Don't really know if that helps deter the little beasties, but I have never had an issue, and I store all Winter, as you know!
The Anti moisture bags also work well, and yes, West Marine is a good source... I think you can order the bags on line... or there is a West Marine store in Holland, just off of the four lane, on the West side of the road, and North of the Discount Mall...
BTW, thanks for the CD's! Perfect! Great work!
