AAV = All Activity Vehicle
ABD = Automatic Braking Differential
ABS = Anti-lock Brake System
ACC = Automatic Climate Control
AFAIK = As Far As I Know
ASR = Acceleration Slip Reduction
ATF = Automatic Transmission Fluid
BAS = Braking Assist System
BTDT = Been There, Done That
BTW = By The Way
CAN = Controller Area Network
CAT = Catalytic Converter
CDI = Common (Rail) Direct Injection
CIS = Continuous Injection System
CO = Carbon Monoxide
DAPO= Dumb *ss Previous Owner
DI = Direct Injection
DIY = Do It Yourself
DME = Digital Motor Electronics (DME) engine-management system
DK = Don't Know
DOHC = Dual OverHead Cams
DRL = Daytime Running Lights
ESP = Electronic
Stabilization Program (also 4-ESP on 4-wheel drive vehicles)
ETR = Emergency Tensioning Retractors (seatbelt part)
ETR = Evaporator Temperature Regulator (climate control part)
ETS = Electronic Traction System (also 4-ETS on 4-wheel drive vehicles)
FI = Fuel Injection
FS = For Sale
FSS = Flexible Service System (that little "wrench" light on the dash)
FUBAR = "Fouled" Up Beyond All Repair
FWIW = For What It's Worth
FWD = Front Wheel Drive
FYI = For Your Information
HC = HydroCarbons
HFM = Hot-Film Mass-airflow (sensor)
HP = Horse Power
HTH = Hope This Helps
HTML = HyperText Markup Language (forbidden on this list!)
HTTP = HyperText Transfer Protocol
HVAC = Heating, Ventilation, & Air Conditioning
IANAL = I Am Not A Lawyer (usually followed by "but" and a legal opinion)
IAW = In Accordance With
IMHO = In My Humble Opinion
IMNSHO = In My Not So Humble Opinion
IMO = In My Opinion
IOW = In Other Words
IP = Injection Pump
LMAO = Laughing My A$$ Off
LOL = Laughing Out Loud
LSD = Limited Slip Differential
MFI = Mechanical Fuel Injection
NLA = No Longer Available
NOS = New Old Stock
NOx = Oxides of Nitrogen
OE = Original Equipment
OEM = Original Equipment Manufacturer
OBD = On-Board Diagnostics
OD = Outside Diameter
OTOH = On The Other Hand
PITA = Pain In The -- well, you know...
PO = Previous Owner
PM = Preventive Maintenance
PS = Power Steering
RKE = Remote Keyless Entry
ROTFL = Rolling On The Floor, Laughing
ROTFLMAO = Rolling On The Floor, Laughing My A$$ Off
RTFM = Read The "Funny" Manual
RTM = Read The Manual
S/B = Should Be
SNAFU = Situation Normal, All "Fouled" Up
SOHC = Single OverHead Cam
SRS = Supplemental Restraint System (airbags & belt tensioners)
SUV = Sport Utility Vehicle
TIA = Thanks In Advance
TDC = Top Dead Center
TDM = Technical Data Manual
TO = Trap Oxidizer
TSB = Technical Service Bulletin
TTO= Trailing Throttle Oversteer (Newbies need to be aware of that one!)
TTYL = Talk (or Type) To You Later
URL = Uniform Resource Locator (website address)
VBG = Very Big Grin
VIN = Vehicle
Identification Number
WOB = Waste of Bandwidth (a message that's irrelevant)
WRT = With Regards To WTB = Want To Buy WTG = Way To Go!
WX = Weather
YMMV = Your Mileage May Vary
And what about :-) and , you ask?
Because there's no eye contact or voice intonation in e-mail, it's sometimes helpful to punctuate messages with textual emoticons known as "smileys." A smiley can clarify the writer's intention when it might otherwise be misinterpreted.
The semicolon-hyphen-close parenthesis combination at the end of this paragraph is a wink. Tilt your head towards your left shoulder and you'll see a little "smiley face" with its right eye winking. I know it's a pain in the neck, but it's better than making enemies because someone took something you wrote *too* seriously. ;-)
There are literally hundreds of smileys, but here's a short list of the most common ones. Some people use them more than others, but most people use them occasionally.
:-) Smile
;-) Wink
:-D Laughing, big smile
:-( Frown
:-\ Chagrin, puzzlement
:-P Sticking out tongue
:-* Kiss
