whitey
Sep 22 2007, 09:14 PM
I'm stripping my car for paint. How is the front targa seal and front door window seals removed. It seems as if these three seals (front targa seal and front door seals) are connected as one.
Thanks, Dave
craig downs
Sep 22 2007, 09:37 PM
The seal is all one piece it goes across the top and down both sides of the windshield.
For the sides you can try to slide it up and out. If that doesn't work start at the bottom
and work it out of the groove of the aluminum strip. The top just slides off the
windshield frame just be careful
craig downs
scotty
Sep 22 2007, 09:47 PM
...and there may or may not be a screw through the rubber to the windshield frame on the inside of the joint between teh top and the side on both sides.
If it's old and cracked, you're going to need a new one as they tend to come apart at the above mentioned joint.
good luck!
addwestern
Sep 22 2007, 09:48 PM
I like using a little silicon spray around the edges- helps not to torque the seal that much.
markb
Sep 22 2007, 09:50 PM
I'd spray the heck out of it with some kind of rubber lube before you remove it, unless it's going to be replaced.
Dave_Darling
Sep 23 2007, 12:29 PM
One way is to tell your local 914 friends that your seal is complete and unbroken, and then leave them alone with the car for a few minutes.
--DD
scotty
Sep 23 2007, 01:55 PM
QUOTE(Dave_Darling @ Sep 23 2007, 11:29 AM)
--DD
Soooo true!
Richard Casto
Sep 24 2007, 01:12 PM
I tried to document the process I used. That thread is here...
http://www.914world.com/bbs2/index.php?sho...64305&st=24I can't edit the post in the classics forum now, but the URL for the process as described in that thread has been changed to...
http://motorsport.zyyz.com/project_914_02_10.htmFor me the entire process is a moot point as I probably will now just buy the replacement seal that was NLA at the time I documented the process.
