QUOTE(Dr. Roger @ Sep 24 2007, 10:25 PM)
Ummmm,
the "hard" brake lines don't flex.
ergo not a fix for the spongy brake pedal.
unless you've got a leak somewhere. that's a whole 'nuther story.
17mm master cylinders always have a little apparent spongy feel compared to modern cars but that's normal.
another known issue is firewall flex. have you searched our brain trust on that issue?
I understand that they don't flex, but if they are corroded from the inside out (much like galvanized water pipe does), the opening for brake fluid to flow becomes a pinhole. The restriction to flow gets so high, your force applied to the brake pedal can start flexing it..
Maybe my definition of "spongy" is really my leg flexing the pedal and linkage to my newly rebuilt 19mm master cylinder. Yes.. I have Nose-Tackle thighs and used to compete in powerlifting so I coudl be very well making the pedal a "spring" unwittingly...
I found this same problem in my buddies '64 Mustang GT. We were going crazy rebuilding everything and still getting no pressure at the calipers until we took apart the "body" lines.. they were horribly knecked down from entrapped water corroding from inside out.. you'd never know it looking at the lines from the outside.
Anyhow, I have one "vote" for engine out to change lines. It's not lookin' good.
