David_S
Sep 25 2007, 12:30 AM
I started putting my rear suspension back together tonight and decided to see what I had between 3 different cars. The shocks off of this car are Boges. One seems like a decent shock, the other is shot. The 72 that I picked up a couple of months ago has new looking KYBs on it. Don't know what shape they are in. My 76 parts car has Koni adjustables on it. They are marked 9-72 Special D. I went ahead and pulled them off and one has no resistance, the other one I pushed in and now it won't come back out. I tried pulling it out and no luck. Can the Koni's be rebuilt and if so, where?? As bad as I hate to, I may have to run the KYB's for now until I can get a better pair. Thanks in advance !!
craig downs
Sep 25 2007, 12:38 AM
From what I have read the cost of the rebuild is almost as much as a new set. I to
have some that the seals need to be replaced but I think I'll just buy new instead.
RON S.
Sep 25 2007, 06:06 AM
Koni's are a lifetime shock as they are rebuildable as many times as you wanna send them off to get them rebuilt.
Truechoice is where I sent mine a couple years back to have rebuilt.
The basic cost was 150.00 per shock plus parts.The final cost was abut 400.00 for the pair.
If you want info,the 800# is in the pic,and ask for Phil when you call.
Ron
purple
Sep 25 2007, 03:40 PM
does anyone see the problem with that picture?
Joe Ricard
Sep 25 2007, 03:50 PM
Yea Ron has nicer shocks than most of us. specially with the added adjuster for compression on the bottom.
Shoulda went with the Sperical bearing option.
There is a difference in off the shelf Koni's and what Ron has which when done by true choice the valving can be specially matched to the spring rate of the car.
Start going really fast and you learn them stiff 200 lb springs can be controlled by a OTS Koni sport.
So.Cal.914
Sep 25 2007, 04:03 PM
QUOTE(purple @ Sep 25 2007, 02:40 PM)
I think that is to compinsate for the weight of the driver. Very observant.
purple
Sep 25 2007, 04:18 PM
the bumper on the lower shock is upside down. As I recall from the miata days, you put this on with the fatter end toward the shock. Supposedly this keeps the bump stops progressive
Aaron Cox
Sep 25 2007, 05:26 PM
does the bumper orientation really matter... it just gets squished....
Cap'n Krusty
Sep 25 2007, 05:29 PM
They can't/don't rebuild shocks which have been bottomed out, and there's no warranty for such damage. The Cap'n
So.Cal.914
Sep 25 2007, 05:35 PM
QUOTE(Aaron Cox @ Sep 25 2007, 04:26 PM)
Being a Professor of SQUISHOLOGY I would have to say No (you were lucky I was around Aaron) (Or Not)
