QUOTE(Johny Blackstain @ Sep 28 2007, 03:25 PM)
Convoluted, is the best way to describe the system
You have a lever , in front of the stick shift, mounted to the floor, operating a cable, that goes back to the tranny, through it, operating a linkage assembly, that operates a rod, that goes back forward to the engine, through the sheet metal, that links to the carbs & holds them a bit open for warm up. This is why I was saying it's a big deal to have a 914-6 tailshifter, updated to a side shifter @ the ECC.
In theory you could use it as a manual cruise control... not adviseable.
Well, that's NOT TRUE at all. On a 914/6, there's a lever in front of the shift lever, and it pushes a rod, which passes through a bushing (located in a little bracket bolted to the tunnel), that presses against a tab on the throttle bell crank on the pedal cluster. The tab is not present on the /4 bell crank.
On the 911, the lever moves an adjustable stop on the throttle rod, which extends from the throttle bell crank on the pedal cluster to the bell crank on the transmission (with a vibration damping coupler near the end).
The Cap'n
