I had a PW switch mounted in the rear part of the center console, jus in fron to the armrest. The center cosole has been removed now and I'm trying to remount the PW switch in the same general location.
My question is whether running the wire loom inside the tunnel to the forward inspection hole would cause unintended problems.
My plan B is to run the along sde the tunnel under the carpet
Any help will be appreciated, and...PW = power window...
Jim
