QUOTE(Cap'n Krusty @ Sep 29 2007, 02:27 PM)
You have the washers in there? Is it stuck in 2 gears? The Cap'n
Transmission will shift into all gears. I just removed the shift console to verify that the forks slots are aligned up and they are. Washers under the expansion bolt are in place.
I just discovered that I can torque the passenger side and all is good. As soon as I torque the drivers side (under the starter) more than 30 inch pounds I have trouble. I removed the expansion bolt and pulled the output shaft. Something inside slipped. The "whatever" the expansion bolt threads into had moved out of position. It took some fiddling around to get it back into position. Still same problem.
I matched the gaskets to the thickness that was in the transmission before. I am fairly certain the transmission did not have this issue before now. But could the pinion drive gear preload (as adjusted by the gasket thickness) set too high cause this?
