Ok...
long story... here is clif notes version.
Motor built 4 - 5 yrs ago. 1971 cc. 8.0:1 motor. Web 86 medium carb cam. built with head gaskets.
euro race header, mallory dizzy, cdi, coil. 1.7 rockers with 911 swivels, solid spacers. Manton pushrods yada yada.
Motor ate a headgasket.
Craig downs did most of the work, along with john edwards my machinist (costa mesa RD - you can read him in sand sports magazine).
New top end. Heads had some cracks. John took care of that.
New motor is 9.4:1, i want to say 54cc heads (did all that a few months ago), redid sparkplug threads etc.... basic r and r.
craig mostly and i developed a new style of full flow exit from the case. instead of a pump cover with 2 extra 90 degree turns to exit the case, we bored out the stock path from the pump up to the stock filter area... made a large block off plate to a -10 braided line to a remote filter with no bypass, and then into the case using the standard brass elbow.....
works flawlessly....
anyway.
Today....
finished with all the ancilary crap. headers etc gnition is all hooked up. Optima battery still had 12 volts after sitting for 6 months.... so we put a charger on it.... more on this later.
spun the motor w/o plugs to get pressure and circulating fresh oil into the 20+ feet of front cooler lines.....
built oil pressure. hooked up plug wires and CDI box....
fired FIRST TRY!. good stuff. Nice strong sound. Carbs are pretty close from last incarnation.
its alive. rumbles like a mofo with just a stinger on the header (have to paint the GT muffler still)
bad news. Charger fell and took out a LARGE piece of paint off the car. Great....add more shit wrong with the car.
All it needs is axles and it is ready to fly to school
Thanks craig for all the help. Doing what i couldnt with my busy work/school situation.
