fiid
Dec 26 2003, 03:09 PM
Hey,
So with the ride height set at an acceptable level, the spings are at rest and the shock is at nowhere near full extension. This mean that if I get air, the spring will be free to float around between the perch and the top cap.
Is this okay? Normal? If thw spring supposed to be wired to the top?? There are a couple of holes in the the spring cap that look like they might be for wiring.
Thanks in advance,
Fiid.
TimT
Dec 26 2003, 03:26 PM
If the spring supposed to be wired to the top??
Yeap, you can wire it to the hat, or get helper springs which will keep the spring in position at full droop.
its easier to wire the springs to the hats
fiid
Dec 26 2003, 03:29 PM
What would be a recommended material for somone who doesn't have any racing wire at the present time??
Cable tie?
Coat hanger?
Fiid.
machina
Dec 26 2003, 03:39 PM
a couple cable ties should work, you won't have to think about it again.
worked for me.
dr
fiid
Dec 26 2003, 03:44 PM
Yay - you guys rock.
Thx.
ChrisReale
Dec 26 2003, 09:36 PM
Fiid, I used cable ties also. What weight did you get?
DNHunt
Dec 27 2003, 08:21 AM
Glad I saw this thread. I forgot to tie the springs down.
Dave
Eric_Shea
Dec 27 2003, 10:36 AM
Let's see... forgot that I drained the tranny. Forgot to tie down the springs.
"Hey Honey... Where'd I put that 914?" "It's still in the garage Dear..." "Ohh... yeah... Thanks!"
