QUOTE(woobn8r @ Oct 2 2007, 06:43 AM)
You might also try doing your downshifting while you are brakeing before the corner, and accelerating through the corner.
Think "slow in fast out"...
That's really proper technique for most corners. Still, the thing should be able to get into gear mid-corner. Have you gotten under the car and checked your mounts? I know 'stock' is an ugly word to us weekend canyon 'racers' (I'm one too), but the stock tranny mounts work just fine if they're in good shape and you're not putting too much torque to them.
If your syncros in the gearbox are REALLY worn out, it won't go into gear at all on a downshift (I had a box like that once). However, if they were that bad you'd probably have some grind or noticeable problem up-shifting as well. If you don't have that, then I'd say get under there and check your mounts, and just replace them with stock for now if necessary. In the meantime, work on getting your car settled before the corner (Uninvited advice). Also, McMark has a point. Be mindful of your body position when under lateral G-load.
Mark D.
