QUOTE(2-OH! @ Oct 3 2007, 04:40 PM)
Ground it in the front...I used the ground by the headlight bucket...
If your car is a 73-74, are you going to cut the front bulkhead for access under the tank, or take the tank out each time you need to service...My pump is 30+ years old, gonna' fail soon...
I mounted mine in the front space in the corner by the spare tire...That way I can get to it and the filter without removing the tank...Made a sheet metal cover to protect and ran the hoses through the front bulkhead using two 1" holes in the bulkhead...
I used the larger line as the return and the smaller line as the pressure...
2-OH!
Thanks for the reply. I was planning on mounting the pump and filter under the steering rack cover, but I do like your pump placement idea. I may put it up top somewhere instead. Maybe even put it in the stock location for a 75-76 since I have a couple of spare pump covers.
I need those SS lines for my 74 does anyone have a link or email?
