QUOTE(RoadGlue @ Oct 4 2007, 05:49 PM)
Thanks JP,
Other than the bumpsteer problem, I happen to like the way my lowered car looks and rides and I use it for both the street and track. Why wouldn't this "shittage" be necessary for a lowered street car if the WM rack spacers don't fix the problem? But really why would it matter if I didn't auto-x or do DE events? The problem would still be there as a street car. Aren't streets and back roads bumpier than most tracks anyways? In fact, I don't notice it much when I'm on the track. I'm too focused on everything else I guess.
I run on an AX venue that is very rough. 21mm Tbars, 275 lb rear springs, revalved shocks, & slicks. The car is set at 4-3/4 inch, doughnuts to ground. I know or folks that run lower and I would if we had smooth venues.....gets your CG down a bit,
I'm no big fan of running on the bumpstops.....instant traction loss on which ever end it occurs not to mention the added stress on the suspension bits.... thus the raised spindles.
No offense, but I could care less about the "look". Checking my present suspension travel I could lower it another half inch......but could you tell the difference?
This is a fairly smooth venue
