Title says it all.........
Replacing the oil cooler seals with the engine out of the car. Normally a 1-2 hour job has turned into 1-2 DAYS. I'm getting damn frustrated. To add to it all, when I got in there and replaced the seals, the old seals were practically brand new and pliable with no visible leakage. .
Anyways, I'm having a hell of a time simply getting the oil cooler retaining nuts back on. I got the two on the actual oil cooler itself threaded and snugged, but the third one more towards the engine case (and hiding behind the cooler) is a BITCH to get to . Now I dropped the nut and it's hiding somewhere in the little cranny behind the cooler.
Keep in mind I did this without removing the cooling fan housing....
Is there ANY way at all to move the fan housing itself a few inches forward (away from the cyl. heads) so I can get room in there to screw the nut back on properly? Will I have to remove the fan? I don't want to deal with that, since it's foreign territory for me.
Please Help!!
