yeahmag
Oct 10 2007, 07:50 PM
It seems that my Sachs clutch and pressure plate are at odds with one another. The pressure plate mates up with the flywheel fine if the clutch is not installed, but when it's in place it's as if it's too thick.
Ideas?
-Aaron
Cap'n Krusty
Oct 10 2007, 08:28 PM
You DO realize the disc is under substantial pressure until it's activated, right? Did you have the flywheel cut? The Cap'n
yeahmag
Oct 10 2007, 09:00 PM
Yeah... It's cut. It just seems to be much harder to draw up than what I remember.
yeahmag
Oct 11 2007, 02:03 AM
Anybody have the wear specs laying around for the flywheel? I can't seem to find it anywhere on the board...
I'm after the pressure plater mating surface to clutch face surface of the flywheel. I just want to be sure my flywheel is in spec there before I run these things up tight.
Thanks.
-Aaron
