QUOTE(JOE M @ Oct 12 2007, 06:59 AM)
O.k I took my heat exchangers out because of a leak. I found a few pin holes and patched them. I still had a leak and it was obvious it was coming from under the tin covering the H.E. I pulled the tin apart and found that there was a weld that was leaking (small hole in the seam). The tin was real bad to begin with so it was probably dangerous at that point(co2). Now I have the pipe patched but the tin is probably not repairable. Does anyone know if there is aftermarket tin to cover thie pipe or can I safely run it without the heat cover( I guess meaning no heat or defrost)? I would like to get SS. but right now I have limited money.
Hey, Joe. I've been looking for a left side HE for a year. Your options: As long as the exaust is good, go without the HE or make yourself a new one. I am told that with a little metal working skill and a good model to work from it can be done.
My trouble is I don't have one to work from.
