That is a stock bar for sure. If it's 18mm then it's a now uber-rare 1976 930 bar. This was the only year 930 to have the through body bar. The number 18 will be stamped on the end of the bar... pretty simple.
I have them on both my cars and absolutely love them for the lightweight Porsches.
This will be hard to explain however; one way to tell if it is the 930 piece is to look at the arm where the bar goes through it. On the stock 13-16mm bars the diamond pattern where the bar goes through is simply stamped out of the arm.
On the 930 arms that area is reinforced with a couple pieces of angle stock the bar now slips through.
Now I just realized that I have some pictures of the bar that I put in my RS clone. That and a few arrows will help explain a few things. The regular 914 and 911 arms are "almost" identical but not beefed up in the areas the arrow is pointing to. The stock size was probably never an issue for over stressing this area:
Click to view attachmentHere you can see how that reinforcement runs through the arm:
Click to view attachmentMounted on my ass-dragger:
